Whelp, it sounds like I'm being volentold into the sled this month. I don't want to leave my bleed air! At least I'll be getting a little raise. Anyone got advice for a first time sled driver? Also this will be my first commercial PIC experience, so general advice about that is much appreciated!
Oh man...
The rudder has a long arm. You need it, but it's more effective than you'll initially expect.
Always check the latches on the aft half of the aft baggage door.
Put the seat pins back in when you take the seats out. Each seat.
Try to never put yourself in a position where a power failure means death. Corollary to that is that the 207 glides like a brick. Compared to the cherokee 6, it's an aerodynamic brick, but still a brick.
Rudder trim. Elevator trim. Use them early, use them often.
They're great airplanes. I have all the respect in the world for them...
... and yet unlike the caravan, If I never fly one again, that'll be A-OK by me. :>
Oh, bonus tip! GET A GOOD HEADSET.
Also, the most important tip I have for you, and this is related to the PIC side of AK flying:
Just because you
can doesn't mean you should; just because the airplane
can doesn't mean you should. Just because someone else
did doesn't mean you should; just because someone else
said doesn't mean you should. Just because someone else
made it doesn't mean you will.
-Fox
