DrBenny
OK, how about this:
I know, I know. One CFI put it even more succinctly: "Make it look right." That's how I am in the 150 and 172. But I still think that in the beginning it is helpful to have some general MP/RPM settings on base and final. It is hard when you are just thinking "reduce power a bit."
So what I'm up to now is thinking, simply, 20 inches once I've turned on downwind. Abeam the numbers, 15 inches, prop forward, and flaps 10, to stabilize at about 85 and a gradual descent.
Now, I can leave the prop alone, and just "fly" the throttle.
Base, 12 inches and flaps 20, airspeed 80 (trim should not need to be adjusted much because I should be descending at the same rate, but slower).
Final, power nearly all the way back, full flaps, airpseed 70-75 kts. Trim. Fly it like you would a Skyhawk, power-off.
Sound like a good starting point?
You know the best thing that helped me out with pitches, power settings, etc was some advice from a UPS 747 captain.
"Do whatever it takes to get the airplane to do what you want it to do".
Being a former Riddle student, I was almost obsessed with power settings, manifold pressures and pitch settings to get specific performance out of the aircraft.
Once I "freed" myself from expecting a generic pitch/power setting my flying improved 8-fold.
Cruise power in an -88? I have no idea. Stabilized approach with gear down and flaps 40? No idea.
Concentrate on being proactive and putting it where it needs to be for your desired performance and you'll be a'ok fine.
