xargos
=crab then sideslip?(works for me)I see no reason as to why we can't have both.
Can you still "feel" the mains touch down in a large jet? Or how else do you figure out the upwind main touchdown?As the upwind gear touches first, a slight increase in downwind rudder is applied
TP
Here's how it's done by the pros. BTW, the landing gear can be offset by +/- 20 degrees. During approach the offset is calculated and dialed-in.
You wouldn't even try a little rudder at the last second?
No. Too much rudder authority with gear down, and in the 117 you'll induce an undesirable roll. Just prior to touchdown isn't the time to be messing with a stabilized approach in these planes, especially at around 180 knots +/- in that jet.
Wow. How many sets of tires did you go through on a sortie? That sounds kind of cool.
They lasted pretty long, as severe crosswind landings weren't common. The homedrome had three runways, 4-22, 16-34, and 7-25, so most wind combos for the area were taken care of. But of course there were those times.
I remember doing a TACAN approach at ROW, circling to a low approach, less than an hour after takeoff. Just prior to commencing, and having computed the speeds for the approach, the speed for circling Cat E around to the runway, at the current aircraft weight so soon after takeoff, came to 215. And even that was tough to keep within the Cat E circling area.
Awesome. Yeah, I wonder if there any civilian airplanes out there that book at those speeds.
I can't even imagine what that would look like!They lasted pretty long, as severe crosswind landings weren't common. The homedrome had three runways, 4-22, 16-34, and 7-25, so most wind combos for the area were taken care of. But of course there were those times.
-groaning sound-I used to set a side-slip at about 200 feet. Old habit from my UND days to make sure I could actually straighten it out and remain stable.
Well, to be fair, you still use them, but yeah.I de-crab at about 10 feet now and prefer that. It works well in lightweight turbo-trash too. The Metro ailerons are stupid and the Brasilia yoke is stupid. So not having to use them, or as much of them, is a win for me!![]()
