Is my understanding correct the en route uses the SF-86, and terminal uses the SF-85?
M meo0o7 Well-Known Member Jan 4, 2009 #1 Is my understanding correct the en route uses the SF-86, and terminal uses the SF-85?
Tony Montero New Member Jan 4, 2009 #3 Just to be 100% accurate, terminal uses the SF-85P. I only mention this because there is a small difference between the SF-85 and SF-85P.
nathanw New Member Jan 5, 2009 #4 Tony Montero said: Just to be 100% accurate, terminal uses the SF-85P. I only mention this because there is a small difference between the SF-85 and SF-85P. Click to expand... Yep, that second one has a P at the end. :crazy:
