Further, if you read in Paragraph 3 Line 2, "Feathering of a propeller is accomplished by moving the control fully aft through the low RPM detent, into the feather position."
This is if you have not already lost oil pressure. You need to dump the oil pressure from the prop hub if there is still pressure that is being created by the windmilling engine turning the oil pump.
That's Piper's own POH saying that to feather a propeller you must move the control fully aft into the feather position. It doesn't get much more clear.
Yes, if there is still oil pressure.
