futurepilot1
I noticed quite a few freight operators still use 727-200 and DC-10/MD-11s. What is the function of the "Second Officer" ??
Flight engineer. Same/same.
Generally an SO is a pilot who is starting out in the FE seat and awaiting upgrade, just as was normal for the pax airlines not too long ago. A PFE (professional FE) is one who isn't a pilot, but is generally an A&P, who stays permanently as an FE.
So they are still performing flight engineer duties?
Yes, they are FEs. Both are FEs. Second Officer is the historic title generally given to FEs who happen to be pilots.
Some of us are interested in what the flight engineer does, as the last true "owner" of the aircraft, in terms of their in-depth knowledge of airframe and systems. It'd be good to know where is 'good' and where is 'bad' to fine out more...
It sounds like an SO is an FE and a pilot - you can't just put a pilot in the SO seat with no prior qualification (or can you?).
Alex.
Almost all of the cargo airlines us PFEs. It is not that they need very much work done on the road; it is that an A&P can sign the aircraft off to fly home to get the work done. I think FedEx is the only US carrier to still put new pilots in the FE seat. FEs will not be around too much longer as most of the aircraft will be obsolete in a few years. Do not think that getting an FE ticket will help you in anyway. There is an outfit in Miami that will try to tell you otherwise, and try to sell you an FE program for about 6K. A good friend of mine sent his son to do this a few years ago and he got his FE ticket and never found work. Most of the carriers that use FE’s want an A&P. These airlines will pay for the FE once hired. SO DO NOT GO TO AEROSERVICES and buy an FE ticket.
FedEx to my knowledge has never used PFE's professional flight engineers. They only hire pilots for the FE seat..Also the only a/c left in the fleet that uses an FE is the 727's which being retired. I do believe UPS has used them in the past but as they parked the last of their DC-8's they no longer have any a/c that have FE positions..It is a dying breed..About the only place outside the military is the older cargo outfits that still fly DC-10's and 727's..
Are all of UPSs 747s gone too?
I noticed from the FAA ATP Written Prep that one of the captain/FO has to be able to perform the duties of the FE in case of incapacitation.
Also, FEs are required on all 80,000lb+ MTOW planes certified before 1963, and dependent on their inclusion on a type certificate after 1963.
Are there any 80,000lb+ aircraft from the late 50s still flying - surely there are some a/c (outside of the usually quoted 727, 747, DC-8, DC-10) which require FEs also?
Alex.
