B767
I don’t think it was an issue with callouts. It seems, to me at least, more of an issue with technique. In my old SOP it never told you WHEN to switch to white needles. Just had to be done before selecting NAV. So in his case it must be done before 1,000. It seems more like it was the instructors technique to do it earlier on in the process as opposed to you know, fly the plane, make sure you’re not out of whack, autopilot on, then switch to white, few hundred feet later press NAV.I honestly meant no disrespect in that reply. The fact you had to look to see company guidance says a lot. I understand things go missing in between training events, but if I posted a question calling out an instructor, I’d make sure I knew my job as far as SOP and callouts.
I really do mean no disrespect, but this is our job, to operate the machinery like our bosses say to.
Also, SOP is not technique. We have specific callouts for all your questions in this thread. Your SOP apparently is different.
Kind of like on a V1 cut. The profile in the SOP tells you to lift off at Vr. Well if you do that chances are you’ll drag a wing (because V1 and Vr were like 1 knot apart). I always left the plane on the ground, got it going straight, then lifted off. By the time I was in the air I was usually right around V2 already. Never got in trouble for it, but that wasn’t in the SOP. I can definitely lift off at Vr in what I fly now as V1 and Vr are separated by quite a bit and it’s already going straight by Vr.
