But when are you "established" in the fix? I believe it is when crossing the fix for the first time on the inbound leg, but I've been told ATC wants you to make the call when crossing the fix on the entry.
The only report that the AIM requires is arrival AT a holding fix. There is no standard "established" in the hold report. That being the case, you can't do it wrongly. In general, ATC doesn't care what you're doing in the holding area, as long as you remain there.
So established inbound, vs performing the entry maneuvering, is immaterial. When I receive the (rare) request to report "established" in the hold, I report after crossing the fix during the entry.
The Canadian version of the AIM does defined the term "established in the hold" and defines it as being established on the inbound course. Midlifeflyer also identified an obscure FAA document that permits ATC to reduce their separation requirements from holding patterns once the aircraft is established inbound, so there is a plausible reason why ATC might be interested. However, since this fact isn't printed in either the Air Traffic Controller's Handbook or in the AIM, it suggests (to me) that the ATC isn't really that interested.
I have submitted a request to the AIM people that they consider defining the term. The said they would embark on "discovery" to see if the term needed defining. That was at least 6 months ago and I've heard nothing since. It's not in the AIM yet.
I also discussed the issue with Wally Roberts, who is a nationally renown expert on instrument approaches and ATC procedures, and he was mystified about why any controller would be interested in whether or not the aircraft was established inbound. He saw no value in defining "established in the hold" in the way that Canada does and said that if any controller complained about not reporting when established on the inbound leg, the pilot should call up on the telephone and complain to his supervisor.
