Tld
Waffles Brah.
You actually work? I thought you sat around the crashpad and solved the world's problems.
Eh, Some from column A, Some from column B.
Got a line next month
I thought she chased pupper doggos around the airport!You actually work? I thought you sat around the crashpad and solved the world's problems.
Got a line next month![]()
I'd go with SC unless you are very close to upgrade and/or can get hired as a sim instructor at your regional. If you aren't a CKA or instructor then the risk of getting stuck at the regional for 10-15+ years is too high. Also, if you take the SC job you still have a decent shot of getting on with a legacy without any TPIC. Look at what UAL is already doing, bypassing regional experience and hiring 1500 hour flight instructors directly through the CPP.
Huh?
Edit: you mean the commutair guys doing the CPP at the start of their job at commutair?
The Lufthansa Flight Academy CFIs with 1500 hours flow to UAL with the CPP.
That's... interesting.
Huh?
It’s not really that different going from CFI to a regional. We fly to a lot of the same places except most of the international stuff. The learning curve is steep whether you’re going from CFI to a regional or CFI to a legacy/major.The Lufthansa Flight Academy CFIs with 1500 hours flow to UAL with the CPP.
I’d almost argue it’s easier going to the major since there is a ton of hand holding compared to the regional fire hose.
Huh?
What are everyone's thoughts on Sun Country? I keep hearing good things but there isn't a whole lot of info to go around except APC, which I don't even want to look at. My situation is that I'm starting to have enough hours to qualify for the majors, but probably not enough to go to one of the 'big 3' for at least a couple more years. Is it worth it to get out now, or would it be a better career move to stay at the regionals building TPIC time and then try to get on with Delta/Fedex/etc in 2-3 years? I think I know what I want to do but would like some other opinions. Sun Country would probably be a massive QOL improvement over my current situation, so that is another factor. How are they for job stability and future prospects?
Take (or pass on) a job based on its own merits
Yeah this seems kind of strange. I've taught and evaluated at a 121 airline and couldn't get a call from United.
