Random NAT tracks
Actually it was after all. The pax were cool, the duck was tasty and I got in a great nap enroute so I can't complain! Even got a pretty good flaps 25 landing in Madrid as well.
More later but I'm off to siesta. Zzz!
you gonna work out today after eating that duck? ;)
OK, I was going to try and be clever and look up wat IDG is....
and after 30 mins mucking about on links from google I've figured its engine related, but still not a clue how? or what its significance is to the engine and plane's function?
So if someone'd care to "edumacate" me that'd be fab! :)
Integrated Drive Generator ... its like a fancy 'lectric motor with an automatic transmission duct-taped to it (that's what they told me anyway :D ).
The AM and PM tracks are worked out each morning between NY, Gander, and Shanwick. The tracks are based on winds, weather (storms), and expected volume. In the evening (PM tracks) another track may be added due to unexpected volume or unexpected weather effecting a track.
ATC expects you to file the track associated with your destination... this is for organizational purposes since you will be worked by three different oceanic controls. Each track has it's altitudes and landfalls and makes for a very organized operation. In the event you do not file the track the flight will most likely not get a good altitude (may be capped at or below FL300) or be rerouted onto a track in the air.
As for FANS and CPDLC this is nice equipment to have over the ocean... equipped A/C can be "seen" just like a radar target and using the CPDLC the flight crews can talk directly to the controller rather then the game of telephone to speak via ArInc. On average service requests are handled faster via CPDLC vs ArInc HF.
I got a question.
Say you are on the NAT cruising to or from Europe and there is a long line of severe t-storms, towering to 60,000+ feet. How do you deviate for weather? Do you really see those type of storms out there?
Oh yes...one of the best FCIFs ever..."Due to software errors, crews will discontinue use of SELCAL..." Nothing like crossing the pond for hours on end with the wonderful HF yacking THE WHOLE WAY!!! :banghead:
I got a question.
In the North Atlantic you can encounter significant convective activity... not often but it does happen, more so in the Fall when the water has warmed somewhat. That weather is encountered more so in the Caribbean oceanic environment.
Most oceanic pilots are very proactive... through PIREPS, SIGMETS, and on board wx radar they request deviations ahead of the weather. Generally they request direction, distance to deviate, and how far they will be on the deviation. On the ATC side since they are non radar we look for traffic and if there is none we protect for the deviation. Typically would be like N1234 req to deviate 30 NM right of course for the next 150 miles.
I got a question.
I've been doing it for 7+ years and have never had to deviate more than 2 or 3 miles off track for weather...
You just don't see that kind of stuff over the North Atlantic unless it's part of a major system which the tracks usually avoid...
Kevin
