PropSettin'
Low n Slow
This...It's a flight sim video. At least it appears to be from my phone.
In the video of the B-52, it seemed to weathervane a bit more into the wind after deployment of the chute. Did you ever notice that when landing with a strong crosswind?
So if a 1000 hour RATP is hired at TSA how many hours would he need to upgrade?
I'm just going to leave this right here...
We had crosswind limitations for use of the chute, was about 15 or 20 knots or so knots (don't remember the exact number) due to not only the weathervane effect, but to the drag chute straps tearing apart the underside of the rudders when the wind drags the chute that direction, damaging what is known as the tip caps, which is a multi-thousand dollar repair. And for this same reason, unlike planes like the F-4 which retained its chute while exiting the runway, we had to jettison ours on the runway by maneuvering into the wind, powering up, and pulling the release handle. We could do non-chute landings, but it was a tricky maneuver as you had to land and immediately get the nosewheel down, then get on the brakes, whch would inevitable smoke due to all the accumulated grease because they're hardly used with the drag chute.. Aerodynamic braking was prohibited in the F-117.
Any reason for this? You'd think the FBW could be programmed so you could keep the nose in the air as long as possible and then start to let it down before you slammed it in eh?
Too much cellulite.
I don't have a whole lot of hours in the JungleBus yet, but overall I don't know what to think of this. I'm generally paranoid about dragging an engine/wingtip, or maybe worse, popping the spoilers up on one of the wings with too much aileron input. So in the grand scheme of things, is this the worst landing ever? I don't know, and I've probably done worse at some point in my life.
Who are all the guys I terrorize on a regular basis... @Nick, @NC_BE300, @amorris311, @BlueMoon, what do you guys think?
The AOM for the 175 says something like 16 degrees to smack a nacelle and that seems like a lot of bank to me and would be really really noticeable up front. I would say something around 5 in a stiff crosswind is about right, but honestly never looked to see what other pilots or myself put in, I usually am looking to see how much pitch we're at (which is 6-8 degrees for most)
