I guess it would just be best to file for the equipment you actually have on the plane then ask ATC for direct when getting clearance.
Hold on now...why is it questionable to file /G because of an expired database, but then all of a sudden it's perfectly OK when you start talking to ATC on the radio?
My reasoning is analogous to why you have to file an alternate that meets the 1-2-3 rule, AND you have to choose one that meets the 600-2/800-2 rule......but once you're in the air, you can make any airport your alternate.
When you file your flight plan, and you declare that your airplane is /G, the controllers may very well revolve your entire clearance around your GPS capabilities.
If you file as a /U, however, and then once enroute you inform the controllers that you CAN proceed direct to XYZ VOR, and that will make his job easier, he won't mind it one bit.
A few months ago, I was filed as a /U comming across the atlanta area from Valdosta, GA. As I approached the Atlanta class B from the south, I started getting mad vectors toward the east, and then finally, he said, "IS there any way you can go direct TRBOW??" I told him, "Yeah, the GPS isn't updated, but I can do it without a problem".
Next thing I know, I got a revised routine....a series of intersections that kept me on the path that he would have had to vector me, and I didn't get another vector until I was north of Atlanta, and dodging more weather (those vectors were MY call...lol).
