Roger Roger
Bottom of the list
Just start with some steep turns.What are those?
Airplanes scare me.Aerobatics scare me
The airplane doesn't know the difference. It's all in your head.(But generally only when it's too full of water...)
I've watched the instruments then entering or exiting rain for changes in CHT (piston) or EGT (turbine). So far nothing noticeable.I was actually reading an article about "shock cooling" and the effects rain has on cooling the engine and heat dissipation as a result.
Yes I said shock cooling on purpose.
I have just got into the world of HP airplanes and I keep hearing "don't shock cool it" and can't really find a good case for what shock cooling is.
Lycoming considers CHTs dropping 50c in under a minute "shock cooling", and so would I.
Having said that, do you know what you have to do to get CHTs to drop almost a degree per second? It's simply not a concern for any conventional point A to point B flying.
The biggest variable in engine cooling is airflow through the cowling, not engine power. Therefore, your airspeed and cowl flaps have the most control over engine cooling. I'm currently flying 6 different HP airplanes and I have the same descent profile for all of them. Dial in a -500 FPM descent with the autopilot and bring back the throttle as far as necessary to maintain the cruise airspeed.
Does that descent profile coincide with 1" per 1,000 ft.?
I have fully programmable VNAV. The shiznit.Nope, I don't even bother.
If I'm at 8,000 above my destination, I wait till the GPS says I'm 16 minutes out and dial in -500 FPM. Pull the power back to whatever MAP keeps me from gaining extra speed in the descent. In the Matrix, CHTs are typically around 350c in cruise, and they are in the 320s by the time I am in the pattern.
In just about any airplane, that procedure will work fine.
Yes I stay at the same airspeed (and therefore cooling airflow) during descent. I've watched CHTs carefully and there is only a modest cooldown despite pulling about 7" MAP at the top of descent. Again, I've carefully watched the CHTs when doing this, and there is only a modest drop over 3-5 minutes.I like it, and I will have to try it. In the Matrix for example, are you going the same speed downhill as in cruise?
Yep, during cruise it's pointless unless something's wrong with the aircraft.All you have to do is ask the question"why" and that will end the hand on throttle during cruise non-sense.
