z987k
Well they're the same standards so..I don't think reading the PTS does much good for a 121 ride since the expectations are made pretty clear throughout training.
You guys are wasting time citing the PTS. It's an FAR, and when you are within Class D airspace, the answer is "yes" for large aircraft or turbine-powered aircraft arriving at a runway served by an instrument approach with vertical guidance, and "yes" for all airplanes arriving a runway served by a VASI. See 14 CFR 91.129—Operations in Class D airspace.
Item (3) gives you relief for when it's necessary to land and safely stop. Ducking under the glideslope (visual or otherwise) in an airplane with a long body (i.e., a jet) is generally a no-no, as you might drag various bits of the airplane through the approach lights/etc. if you take it to an extreme.
Even if doing so will have you land half way down a 2,300' runway, as it does at the airport where I learned to fly?
"...until a lower altitude is necessary for a safe landing."Even if doing so will have you land half way down a 2,300' runway, as it does at the airport where I learned to fly?
Why wouldn't it be? On any 121/135 check ride you are held to the standards to what certificate you hold. I've had an ATP for a while now, and I just got a brand spankin new Type Rating YESTERDAY, and guess what one of the first things the examiners did? Broke out the ATP PTS and went over it with me so there would be no questions on what was expected on the type ride.
