Interesting video. The flaps are definitely a sore spot on the -200. At my airline I'm currently transitioning from another type to the CRJ, and we've discussed the flap system quite a bit (and in fact just finished some no flap landings in the sim a few days ago). With the critical wing the 200 has, along with the lack of slats, the ref speeds are VERY high for a no flap landing. Depending on the landing weight, ref can be as high as 172 kts (and even higher if one were to return above max landing weight). This has the effect of essentially doubling your required landing distance (70% increase to be exact). I have no idea what PSA's policy is either, but we are trained to plant it on as well, and to get the nose down fairly quickly so that we can utilize the TRs fairly quickly to help with deceleration from the high speeds seen from a no flap landing. However, we are also cautioned (and the QRH emphasizes this) to "gently" lower the nose to prevent structural damage.
I'm far from a technical expert on the CRJ 200, but from what I understand it essentially carried over the flex shaft design from the earlier challenger series. The problem of course is that the challenger was designed for a relatively low utilization in the corp/charter world, compared to the MUCH higher amount of cycles seeing in a regional airline environment. Landing gear issues are no stranger to this type either. I'm hoping I will be able to mostly bid for the 700...
