A Prop Overspeed occurs when the prop governor (the engine component responsible for maintaining the set prop RPM) fails and as a result, the prop exceeds it's max RPM limitation. Really only applicable to constant-speed prop aircraft, although you can overspeed a fixed-pitch prop too but it's not quite the same.
Ray
