JSFirm Production Pilot 4
Status
Not open for further replies.
NewsBot
Administrator
Boeing Company Seattle, Washington:
Location Seattle, WA
Security Clearance Required? No Security Clearance Required
about security clearance definitions
Position Description
As a Safety Pilot in the BT&E Flight Operations organization, you will be providing flight operations and safety support to Boeing internal customers at multiple levels. Works together with industry partners and liaison with FAA and NTSB. Maintains qualification as a Boeing Pilot on at least one aircraft model. Supports new aircraft and system development and certification efforts. Investigates and makes recommendations regarding company aircraft incidents and safety concerns. Provides information and specialized safety and operational services to Company and customer flight test crews to enhance flight test operational efficiency. Consults with cross-functional teams during accident/incident investigations and analysis. Researches, edits, documents and coordinates publication of safety information for flight test pilots. Represents Boeing as a safety lead by authoring and presenting professional papers at worldwide safety and flight operational forums. Supports sales campaigns by discussing and demonstrating aircraft and new flight technology. Serves as a consultant to senior management and other industry professionals. Job requires FAA ATP or Commercial certificate with the appropriate endorsements. Works under minimal direction.
Competencies
General
[ + ] Communication
Consistently clarifies purpose and importance; stresses major points; follows a logical sequence. Consistently keeps the audience thoroughly engaged through use of techniques such as analogies, illustrations, humor, an appealing style, body language, and voice inflection. Consistently frames even complex messages in line with audience experience, background, and expectations; uses terms, examples, and analogies that are meaningful to the audience. Consistently seeks input from audience; checks understanding; presents message in different ways to enhance understanding. Uses syntax, pace, volume, diction, and mechanics appropriate to the media being used; attends to both direct and indirect messages from others; correctly interprets messages and responds appropriately. Advises fellow project leads and other internal employees in effective communication techniques.
[ + ] Contributing To Team Success
Consistently makes procedural or process suggestions to work group members, fellow project leads, other internal employees, and external customers for achieving team goals or performing team functions; provides necessary resources or helps to remove obstacles to team accomplishments. Listens to and fully involves others in team decisions and actions; values and uses individual differences and talents. Shares important or relevant information with the team. Adheres to the team's expectations and guidelines; fulfills team responsibilities; demonstrates personal commitment to the team.
[ + ] Decision Making
Consistently recognizes a wide range of complex, specialized issues, problems, or opportunities in own work group, across the organization and with external customers; determines whether action is needed. Steadily identifies the need for and collects information to better understand issues, problems, and opportunities. Regularly integrates complex information from a wide variety of sources; detects complex trends, associations, and cause-effect relationships. Consistently creates relevant options for addressing problems/opportunities and achieving desired outcomes. Formulates clear decision criteria; evaluates options by considering implications and consequences; chooses an effective option. Consistently implements decisions or initiates action within a reasonable time. Regularly includes fellow project leads, employees across the organization, and external customers in the decision-making process as warranted to obtain good information, make the most appropriate decisions, and ensure buy-in and understanding of the resulting decisions.
[ + ] Planning And Organizing
Identifies more critical and less critical activities and assignments; adjusts priorities when appropriate. Proactively determines project or assignment requirements by breaking them down into tasks and identifying types of equipment, materials, and people needed. Effectively allocates appropriate amounts of time for completing own work; avoids scheduling conflicts. Is an expert at taking advantage of available resources (individuals, processes, departments, and tools) to complete work efficiently; coordinates with internal and external partners. Uses time effectively and prevents irrelevant issues or distractions from interfering with work completion.
Technical
[ + ] Aircraft Operations
Extensive, specialized knowledge and ability to use standard crew resource management, weight and balance calculations, navigation procedures, airspace, meteorology, aircraft performance data, communication operations, flight planning, industry regulations and pilot aviation skills to perform aircraft operations.
[ + ] Flight Safety
Extensive and specialized knowledge company and industry safety initiatives and strategies to reduce the world aircraft accident rate. Knowledge of operational flight safety, including industry-wide current safety topics (e.g., approach and landing, upset, Controlled Flight into Terrain [CFIT]).
Basic Qualifications For Consideration
Do you have a current Class 2 or better medical certificate?
Do you have at least 3000 hours total flying time?
Do you have an FAA ATP or commercial certification with the appropriate endorsements?
Typical Education/Experience
Degree and typical experience in engineering classification: Bachelor's and 9 or more years' experience, Master's with 7 or more years' experience or PhD with 4 or more years' experience. Bachelor, Master or Doctorate of Science degree from an accredited course of study, in engineering, computer science, mathematics, physics or chemistry. ABET is the preferred, although not required, accreditation standard.
Other Job related information
Required skills: Excellent writing and communications skills
Desired skills: Previous flight safety experience, previous flight test experience
  • Business Unit Engineering Ops & Tech
  • Division Boeing Test & Evaluation
  • Program Chief Test Pilot
  • Job Type Non-Management
  • Experience Level Career/Experienced
    • US Person Status Required? Yes
Closing Date: 03/13/2013about closing dates
Continue reading...
Status
