I’ll be 100% honest. If I am reviewing this for the regional which hired you, and your response is written the same way that the original post is, I would terminate the hiring process. The way it reads just feels like maybe there was an issue and you’re trying to deny it. I would make sure that your response is not similarly vague, or combative and Is supported by whatever evidence you have.
That being said, on a .293/297 if the ride is discontinued there”should” be notification of discontinuance even though the event isn’t a certification type event. Make sure you clearly document when the check ride started, the beginning of the oral. It’s important to remember that oral questioning may continue in a practical test if they feel that an applicant hasn’t demonstrated something correctly.
Part of your problem in this is going to be explaining the termination and then trying to show that the company was still using pria as retaliation. If you were terminated, unless you really really pissed them off, there doesn’t seem to be as much motivation to forge or falsify records for PRIA. From a company perspective, all that does is open them up to legal action. Had you walked off a trip mid trip and been like “see ya, got a job at Mesa” and put them in a bind, then yes retaliating makes more sense. The way this reads, it seems like the check airman didn’t think you satisfactorily passed one of the elements of your ride. You disagreed and elected to stop the ride. It’s important to note that electing to discontinue after a point at which a check airman has informed you of a failed element is still a bust. Along the lines of “you can’t fire me because I quit”. I’ve never been at a 135 shop where the pilot gets to choose who they do a check ride with, and, in the event of a discontinuance unless the original examiner is not able to do the ride, you go back with them - otherwise you start over.
If they are falsifying records, then an attorney is the answer.
I’m not saying that’s how it happened, but based off the short version above, that’s kind of how it reads.
