Roger Roger
Bottom of the list
Problem with trimming for airspeed in a 172 is the propwash on the tail has a very large effect on your trim airspeed. Trim for 65 knots power off (or even at 1500 RPM) and then go full throttle and unless you intervene you will enter a trim tab stall. As long as you're making small power adjustments you'll be ok, but a common trap is getting a little low on final and having to add power (and especially if you are a little slow, the power required will be substantial). Now if you don't correct with a little forward pressure, the propwash on the tail actually makes the airplane seek a slower speed, increasing drag...etc. The technique of trim for speed on short final is perfectly valid in a 172, but you still have to be aware of the interaction of pitch and power.Agreed, to add, the DPE was asking what side of the power curve I was on for a short field landing.
Trimming for an airspeed (at least in a 172) is something that was also new to me.
