Plane covers?
texas_pilot
Previous owner's son claims plane covering ruined all earlier glass in one season.
It was all replaced and is nice now, but I had ordered $500 cover.
Any experiences on this good or bad?
If glass was ruined it is probably because dirt, dust, or other accumulated yuck ended up on the inside of the cover. Make sure the airplane is washed regularly and the cover is kept clean and in good condition and you should be fine.
If your are talking about the 140 you are going goblet your buddy use, don't cover it. They won't take the same care of it you will. Students (well some of them) won't treat it as if it were there own, and you'll end up causing more harm than good. Put up some sun shades, and not thenkind that are reflective. The reflective kind can still damage the acrylic windows.
Some covers use a microfiber-like lining where the windscreen is, designed to be softer and not collect sand. As trafficinsight said, keeping it clean is important. Any crud trapped will rub if wind is blowing the cover a little bit and cause scratches.
I've bought some stuff from Mac's Custom Covers in Michigan. Pretty good work for the price. Airplane-covers.com
Bruce's has awesome covers. Great construction and materials. Their customer support is amazing. If you have a problem, just send it back. Many of my friends had a few things happen after many years and Bruce's repaired or sent new parts for free (buckles, straps, waterproofing spray, etc). Customer support and quality construction is probably the main reason I bought one from Bruce's (definitely not because of the price). Planecover.com seems to be the second best in my opinion. As for the reflective inserts, they are made to protect the interior and keep it cool. They are actually worse for the windscreen.
I'll echo what's been said before- if you don't get a Bruce, make sure it has the microfiber lining for the windscreen and windows. Make sure they are clean before you put the cover on, too. Also, when you put the cover on, make sure to tuck the remaining amount of strap with the rest going around the fuselage so you don't have extra strap beating your paint (hopefully that made sense). For the most part, don't clean the cover with soap (or any cleaner for that matter), either as It will damage the UV and water protection on it, water and brush are best. Using the wrong cleaning products are worse than anything- if your not sure what to use on your new windscreen, never use a glass cleaning product, only use Plexus, Clearview, or one of the "quick detailer" sprays out there. No paper towels either, microfiber cloths only in straight up and down patterns (don't clean windscreen in circular motion). A good coat of wax will also make the bugs come off easier.
No doubt the cover will be a pain to put on at first, but after a few times, you'll get pretty quick at it and it won't be so bad. You'll really enjoy the cool cabin temperatures during the summer, too :) Let me know if you have any questions. I've gathered all that information from my aircraft detailing experiences, other people's covers and my cover. Hope that helps!
