Great link....that was an amusing read :laff:
Kind of relevant here, and lightly dusted over in the previous thread re: Aero for Naval Aviators; it is not used at API anymore, and has been replaced with a much more straightforward and dumbed down workbook. Probably most of the same info (I haven't looked at either book for a while).
I've heard good arguments for both schools of thought, but I'll say that it was nicely explained to me by an old sim instructer (former A-4 driver).....pitch=airspeed at or around on-speed/approach speed, and power = airspeed at anything above that. Not sure if there is aerodynamic theory to back this up, but it works in practice. But in terms of during an approach, all our LSO's (and other IP's as well) teach throttle for GS corrections, and stick for AoA/airspeed corrections, so this indeed is the technique taught to USN pointy nose jet types. Influencing the nose to correct for glideslope deviations is considered to be bad juju, problem being that moving the nose also moves the tailhook point, which could (when correcting nose down) result in a bolter or hook skip, and at the other end of the spectrum (heavy nose up) could cause an in-flight engagement of the arresting cable. If we weren't worried about proper placement of the tailhook, then I'd say you could just as easily (and actually more efficiently) correct GS deviations with the nose/stick.....when I fly an ILS it is much easier to place the velocity vector right where I want it with the stick (we have the ILS needles repeated in the HUD), and then smoothly correct the throttle to bleed back to on-speed. Compare this with my throttle movements while flying the ball, in which my left hand is moving nearly constantly in small little corrections in order to keep that ball centered on or above the datums. Just thought I would add that since it didn't seem like anyone really followed up on that discussion.
