Piper pilots beware !
IndianaPilot
If and when you check pitot heat, be careful ! Grabbed the pitot static mast/vane like a porn star yesterday after it had been on awhile.....not fun....probably could have boiled water with it :bounce:
Those gear swings are some of the most scary things I did as a mechanic.
This is literally the first time I've ever visualized a Cessna getting jacked and cycled. Who gets to climb the ladder and sit in the cockpit 7 feet off the ground would be my first concern.
The real scary part is when you throw the handle and the plane starts torquing around on the jacks, that and making sure you jacked it up high enough that the wheels would clear the ground.
We generally would unlock the gear and then swing them through by hand to make sure they would clear first.
Well excuse me ! When is a thorough preflight funny ?? I was trying to suck moisture out of the drain hole !
Come on, yall.. we gotta get on the same page here. How are we jacking and draining? By hand or mouth?
I'm so glad these images don't load at work, I'm sure I'd've blown coffee over the keyboard....like a porn star
