A
Adler
Guest
One thing I hate seeing is the FD's "plan" differ from the PF's actions.
Sometimes you have to "look through the flight director"...
Use of automation and managing the other pilot is the challenge in these cases. Often I'll leave the autopilot on and manipulate the FD panel myself.. Once the autopilot is off the PF is essentially useless-leaving the other guy to manage the panel.. The newbies don't have the muscle memory of switch position so they're slow in button pushing and knob turning. If I am planning on disconnecting the AP early I'll tell the other guy my plan and have things set up as much as possible so they have very little to do. One thing I hate seeing is the FD's "plan" differ from the PF's actions.
The engine failure at V1 is truly the worst-possible-scenario in terms of that particular malfunction combined with the need to precisely extract performance from the airplane (although I would say that it's actually slightly more difficult at 400' or on the go-around at initial thrust/power application from an approach setting). Mishandled, particularly in the presence of a complex departure procedure to clear terrain, it can easily lead to a less than satisfactory amount of clearance from said terrain. (For instance) Our CRJ program goes to RNO in the sim on a regular basis to fly those complex departures.
I'm pretty old school. I didn't even know what an autopilot was for the first 12 years of flying. My first job out of the military was flying a single pilot, no autopilot PA-34 hauling rubber checks. RNAV was a KNS-80, and only the high end airplanes had that.
But if you are going to be a pilot you need to be able to aviate, navigate and communicate. If your airplanes has an autopilot, you had better be able to use it, be you a private pilot or an ATP. You should also be able to fly the Expressway Visual 31 to LGA when the winds are gusting out of the South West.
Get over it. It's not an either/or argument. It's a "can you do both" argument. I remember one sim given a simulated pitot/static covered with tape. The FO kept saying it was an ADC failure. I told him it wasn't and instructed him to turn on the autopilot. Instructor said the autopilot would not work. You know what? It did. In the pitch and roll mode. Helped out. We were the first crew to make it through that EP without crashing the first time. Everyone else tried to hand fly it in IMC and failed. I used automation and succeeded.
What?
Airline SOPs. When hand flying, the PF is not permitted to touch the flight guidance controls. ATC gives you a heading change, the PM has to spin the bug, while also talking on the radios and doing check lists, etc.
It's a narrow line to tread. A "good" crewmember will handfly when they can to stay proficient but also keep an eye on the PM to make sure they aren't getting overloaded with checklists and the radio and managing the FCP. Even if you have the FD turned off, the other guy still has to make changes to the FCP despite the fact you aren't actually using any of that right then.
This so much.
Keeping tabs on "the other guy" is one of the best and most important parts of CRM. I love to hand fly. The top three reasons I turn on the automation is 1) The sun is in my eyes. 2) I want to take a sip from my coffee. 3) The guy next to me is starting to get overwhelmed. 4) There is a leveloff coming up.
FIFY
That's the most fun part!No way!
My question is where is @ATN_Pilot? He should have commented by now.
It's good that you'll never hand fly an airplane ever again.This so much.
It's good that you'll never hand fly an airplane ever again.![]()
It feels like I may never SEE an airplane.
