jhugz
Re: Pilot dies as single-engine plane flies 300 miles past d
Let me rephrase it then. Not every emergency is a CAPs pull. I never said that every emergency is a CAPs pull. Sometimes it is not in you best interest to pull the chute. For example a Engine Fire in Range of an airport is an example of a neg chute pull. A Vne decent to the runway is your best bet. However If not over a runway I am using a Vne decent to get to about 1000' AGL and pulling the chute after bleeding the AS back to maxium chute deployment speed. During the decent (under the chute) I am going to do my best to keep the fire behind the firewall with my extinguisher since I no longer need to fly the airplane and then run the appropriate checklists. I have stated the statistics before but I guess I need to do it again.
There has been 48 fatal accidents in Cirri from 2001 to 2009:
Only 3 pulls have been associated with these fatalities.
Only 1 of the three was a legit equip malfunction which was later AD'ed.
Up to 2007 (don't have the numbers afterwards there has been 14 chute pulls with 12 being a success and 28 people owe there life to the system.)
A chute pull is very very survivable and your best option in a Cirri when you tank an engine not over an airport. Take it or leave it...I am throwing numbers at people and they are just bouncing off. I'm pulling the chute you do whatever you want.
