Roger Roger
I am le tired
Guess seaport should stick to caravans.It would be pretty weird if it didn't work. It's a pretty simple system. Guess we'll know in, you know, 1-3 years.
Bi-curious George on the tail is a nice touch I must admit.
By and large I agree with you, and a discussion of the problems that effect the accident rate in 135 is well, well outside the scope of this thread, but in this particular case Seaport is running scheduled commuter flights operating IFR in the flatlands. That's about as predictable as it gets.As far as 135 accident record goes...I think to some extent it is due to lack of SOPs, etc. If you know what the other guy is (or at least should be) doing, you can focus on your job. But I'm betting Seaport has SOPs. If I were to point the finger (in the abstract...no idea what happened here), I'd point it at the fact that 121 guys have essentially one job...fly the airplane. They know where they're going days in advance, for the most part. 135, by its nature, is a bit more "fluid" (that's a euphemism). It is not, by any measure, forgiving of complacency (and I say that as someone who knows because he's done it, not because he hasn't). That said, I dunno how you "fix" that. It's Air Taxi. Bus drivers know where they're going...taxi drivers don't.
FIFY... Bus drivers have a set route...limo drivers don't.
I don't disagree with these people not getting unemployment benefits. However, your statement is a common misconception and is certainly not accurate. You can be fired and receive unemployment benefits, depending on the reason you were fired.
Remember also that a lot of this is state level, so making a specific absolute statement will almost always be wrong somewhere.
-Fox
Incorrect/incomplete. Get back to me once you've corrected yourself.You can be laid off and receive benefits, but not fired. Being fired indicates it is disciplinary in nature.
I'm sure they love riding in it when the weather is right down at 500/2.It seems pretty obvious that there's a balancing act between piloting skill and piloting experience.
Hey now! Out customers love the "Monkey plane"... which is a monkey plane no longer, I might add.
AKA the short bus, or more recently, the mini-van.
-Fox
Even FSI et al pale in comparison to 121 training/checking
That is garbage CFI talk. That statement drives me absolutely freaking nuts.
It is called GPWS...With all due respect, that's BS. How many thousands of 121 operations are there a day, and when was the last time a 121 airliner landed gear up as a result of a flight crew mistake? Obviously the 121 world has something figured out.
