Roger Roger
Bottom of the list
Didn’t part 91 used to be able to just use the MMEL or am I hallucinating that?
I think that was a couple decades ago now. It's a little crazy in my mind that you need the MMEL approved, even though the MMEL is a published FAA document. The one for our aircraft has published M&O procedures and all. I guess thats the FAA thoughDidn’t part 91 used to be able to just use the MMEL or am I hallucinating that?
Our AFM has a KOEL section,but reading part 91 makes me think we can not use the KOEL. At least for turbine operations. @deadstick
Yes it is, but reading the regs makes me think that it is not allowed to be used for turbine ops. It seems like they publish the KOEL as a basis to build the MEL from.Isn’t the KOEL part of the FAA-approved Limitations section?
Well, painful as it may be to admit, it was a couple decades ago that I was first learning this stuff.I think that was a couple decades ago now. It's a little crazy in my mind that you need the MMEL approved, even though the MMEL is a published FAA document. The one for our aircraft has published M&O procedures and all. I guess thats the FAA though
That's interesting to note. But still doubt you can apply a KOEL like an MEL to inoperative equipment. As they reference removing it in an approved manner.I just realized KOEL usage was addressed indirectly in the good ol’ Nichols (2009) LOI that is used in discussions of logging SIC time.
Why you need an LOA to use the MMEL makes no sense, just as the amount of hoops to jump through to approve an AAIP makes no sense. The FAA literally makes it harder to do things the way the manufacturer intended them to be done.
Good thing 91.213 covers all these scenarios
Also, if you work for a 91 jet operator too cheap to get a MEL or fly planes with no writeups...you're probably in south Florida.
Yup. Gotta love that “there’s a letter for that (tm)” though. I’d assumed the KOEL in the AFM was the basis each civil aviation authority created their MMEL off of or something. Seriously, a MEL LOA is stupid simple. I’ve somehow gotten several issued to me.91.213(d) relief only applies to non-turbine, as I read it. So it seems like the answer is that the airplane in this case is grounded.
Haha some of this is beyond aggravating. Hopefully this plane is on the 135 cert sooner than later then.In general, they just want to make sure that your using the current MMEL, and that it’s actually the approved document.
It’s far to easy to “modify” one and present during a ramp inspection etc in an effort to cheat something that you can’t do... like fly at night with an ice light out. I know having the op spec /loa doesn’t mean you won’t do this, however I guess it’s a step better than Wild West.
Our MMEL has some stupid stuff on it. I’d def. like to highlight and delete prior to pushing to the pilots iPads
To the OP - wait until you have a Cat “B” Mel item in your plane - only to find out the part is 5-7 days away, and it’s for something you don’t even need for 91 ops. Say - autopilot disconnect annunciator light PC board. So you do what any good 91 pilot does, and try to get an extension. ( you can’t, the CAT a/b/c/d system if for operators on an approved program, 121,135,91k)
I’ve been out of the D.O. position for only eight months, so I’m pretty confident that you just send the FSDO a letter requesting an LOA D095 to use the MMEL as an MEL. Provide your source for M&O procedures (most manufacturers provide this) and you should be good to go. Not a difficult process at all.I think that was a couple decades ago now. It's a little crazy in my mind that you need the MMEL approved, even though the MMEL is a published FAA document. The one for our aircraft has published M&O procedures and all. I guess thats the FAA though
Guidance (scroll to Part 91 section)
Agreed. The letter is the only thing that I had to generate myself, the other items can be downloaded and attached.The FSDO still needed to see a completed packet including the MMEL with the M&O procedures and also the policy letter from the 8900. This was for an older gulfstream and a FSDO on the west coast.
Never have i ever gotten in trouble with a 135 operator for telling the moron/lying/self-deluded/I-want-reality-to-be-different-than-what-it-really-is DO that I could and would be happy to do a trip 91, but that I could not and would not do the trip 135 because the OpSpecs did not authorize flight to that area/airport... and, you know, that would put both his certificate and mine at risk.Say what? Let’s play a game called never have I ever.
I’ll start.
Never have I ever wanted to do charter /135
