Patrick
Call a prop shop. You don't want to be sanding and/or stripping a prop yourself for a variety of reasons, the first of which is liability. You in your hangar are not equipped to do this job properly. If you sand to bare metal, you need to alodine the metal for corrosion protection. If you chemical strip, you need to be aware of the chemical strippers effects on the metallurgy and how it's going to affect the new finish adhering.
With any of this work, the prop will need to be re-balanced.
I'm not sure what the times on the prop are, but if you want to do this right, the blades need to come off the hub, and at that point, you may as well call it a full overhaul.
If all you're concerned about is the appearance, I'd just live with it until the next overhaul.
