Pain in the a$$
MikeD
Administrator
Staff member
These are the pain in the a$$ flight restrictions I have to deal with Monday...........ughhhhhh.
FDC 3/7143 - PART 1 OF 4 FLIGHT RESTRICTIONS TUCSON AND SUMMERHAVEN, ARIZONA, AUGUST 11, 2003 LOCAL. PURSUANT TO TITLE 14, SECTION 91.141 OF THE CODE OF FEDERAL REGULATIONS AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN 10 NMR UP TO BUT NOT INCLUDING FL180 OF 320959N/1105259W OR THE TUS009004.6 FROM 0308111545 (0845 LOCAL 08/11/03) UNTIL 0308111650 (0950 LOCAL 08/11/03). WITHIN 30 NMR UP TO BUT NOT INCLUDING FL180 OF 322619N/1104535W OR THE TUS005022.1 FROM 0308111620 (0920 LOCAL 08/11/03) UNTIL 0308111905 (1205 LOCAL 08/11/03). WITHIN 10 NMR UP TO BUT NOT INCLUDING FL180 OF 320959N/1105259W OR THE TUS009004.6 FROM 0308111825 (1125 LOCAL 08/11/03) UNTIL 0308111930 (1230 LOCAL 08/11/03). EXCEPT AS SPECIFIED BELOW AND/OR UNLESS AUTHORIZED BY ATC: A. ALL AIRCRAFT OPERATIONS WITHIN 10 NMR OF 320959N/1105259W OR THE TUS009004.6 FROM 0308111545 (0845 LOCAL 08/11/03) UNTIL 0308111650 (0950 LOCAL 08/11/03) AND FROM 0308111825 (1125 LOCAL 08/11/03) UNTIL 0308111930 (1230 LOCAL 08/11/03) AND ALL AIRCRAFT OPERATIONS WITHIN 10 NMR OF 322619N/1104535W OR THE TUS005022.1 FROM 0308111620 (0920 LOCAL 08/11/03) UNTIL 0308111905 (1205 LOCAL 08/11/03) ARE PROHIBITED EXCEPT END PART 1 OF 4 WIE UNTIL UFN
FDC 3/7143 - PART 2 OF 4 FLIGHT RESTRICTIONS TUCSON AND FOR: 1. LAW ENFORCEMENT AND MILITARY AIRCRAFT, DIRECTLY SUPPORTING THE UNITED STATES SECRET SERVICE (USSS) AND THE OFFICE OF THE PRESIDENT OF THE UNITED STATES (POTUS), EMERGENCY MEDICAL FLIGHTS, AND REGULARLY SCHEDULED COMMERCIAL PASSENGER AND CARGO AIRCRAFT THAT MEET OR EXCEED THE TSAS DOMESTIC SECURITY INTEGRATED PROGRAM STANDARDS AND ARE ARRIVING INTO AND/OR DEPARTING FROM 14 CFR PART 139 AIRPORTS. 2. FOR OPERATIONS WITHIN THE TFR ALL MEDICAL FLIGHT OPERATION COMPANIES SHALL COORDINATE WITH THE USSS PRIOR TO THIS NOTAM GOING INTO EFFECT TO AVOID POTENTIAL DELAYS. B. WITHIN THE AIRSPACE BETWEEN 10 NMR AND 30 NMR OF 322619N/1104535W OR THE TUS005022.1 FROM 0308111620 (0920 LOCAL 08/11/03) UNTIL 0308111905 (1205 LOCAL 08/11/03): 1. ALL AIRCRAFT ENTERING OR EXITING THE 30 NM RADIUS TFR SHALL BE ON AN ACTIVE IFR OR VFR FLIGHT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC CONTROL (ATC) FACILITY. AIRCRAFT SHALL BE SQUAWKING THE DISCRETE CODE PRIOR TO DEPARTURE AND AT ALL TIMES WHILE IN THE TFR. 2. ALL AIRCRAFT ENTERING OR EXITING THE 30 NM RADIUS TFR MUST END PART 2 OF 4 WIE UNTIL UFN
FDC 3/7143 - PART 3 OF 4 FLIGHT RESTRICTIONS TUCSON AND REMAIN IN TWO-WAY RADIO COMMUNICATIONS WITH ATC. 3. ALL AIRCRAFT OPERATING WITHIN THE 10 TO 30 NM RADIUS TFR AND OPERATING AT ALTITUDES OF UP TO BUT NOT INCLUDING FL180 ARE LIMITED TO AIRCRAFT ARRIVING OR DEPARTING LOCAL AIRFIELDS AND ATC MAY AUTHORIZE TRANSIT OPERATIONS. AIRCRAFT MAY NOT LOITER. 4. FLIGHT TRAINING, PRACTICE INSTRUMENT APPROACHES, AEROBATIC FLIGHT, GLIDER OPERATIONS, PARACHUTE OPERATIONS, ULTRALIGHT, HANG GLIDING, BALLOON OPERATIONS AGRICULTURE/CROP DUSTING, ANIMAL POPULATION CONTROL FLIGHT OPERATIONS, BANNER TOWING OPERATIONS, COMMERCIAL CARGO CARRIER OPERATIONS THAT FAIL TO MEET OR EXCEED THE TSA(S) DOMESTIC SECURITY INTEGRATED PROGRAM STANDARDS; ARE NOT AUTHORIZED. 5. ALL U.S. SECRET SERVICE CLEARED AIRCRAFT OPERATORS BASED IN THE AREA SHOULD NOTIFY THE US SECRET SERVICE PRIOR TO THEIR DEPARTURE. 6. ALL MEDICAL FLIGHT OPERATION COMPANIES SHALL COORDINATE WITH THE USSS PRIOR TO THIS NOTAM GOING INTO EFFECT TO AVOID POTENTIAL DELAYS WHEN THE NOTAM IS IN EFFECT. C. IT IS RECOMMENDED THAT ALL AIRCRAFT OPERATORS CHECK NOTAMS END PART 3 OF 4 WIE UNTIL UFN
FDC 3/7143 - PART 4 OF 4 FLIGHT RESTRICTIONS TUCSON AND FREQUENTLY FOR POSSIBLE PRESIDENTIAL REQUIRED CHANGES TO THIS TFR PRIOR TO OPERATIONS WITHIN THIS REGION. END PART 4 OF 4 WIE UNTIL UFN
Minuteman
“Dongola”
W gets a 30nm TFR in Crawford and Tuscon at the same time? What the hell?
Welcome to the club. I wish he wouldn't spend so much time on vacation.
tonyw
Now you know what I deal with every single time I fly. Thank you, Mr. President, huh?
