NTSB report on Gulfstream G650 test flight crash
SteveC
Really?
Staff member
Aggressive Test Flight Schedule, Overlooked Errors Led to Stall and Crash of Gulfstream G650
Oct. 10, 2012
The National Transportation Safety Board determined today that the probable cause of the crash of an experimental Gulfstream G650 on April 2, 2011, in Roswell, N.M., was the result of an aerodynamic stall and uncommanded roll during a planned takeoff test flight conducted with only one of the airplane’s two engines operating.
The Board found that the crash was the result of Gulfstream’s failure to properly develop and validate takeoff speeds and recognize and correct errors in the takeoff safety speed that manifested during previous G650 flight tests; the flight test team’s persistent and aggressive attempts to achieve a takeoff speed that was erroneously low; and Gulfstream’s inadequate investigation of uncommanded roll events that occurred during previous flight tests, which should have revealed incorrect assumptions about the airplane’s stall angle of attack in ground effect.
Contributing to the accident, the NTSB found, was Gulfstream’s pursuit of an aggressive flight test schedule without ensuring that the roles and responsibilities of team members were appropriately defined, sufficient technical planning and oversight was performed, and that hazards had been fully identified and addressed with appropriate, effective risk controls.
“In this investigation we saw an aggressive test flight schedule and pressure to get the aircraft certified,” said NTSB Chairman Deborah A.P. Hersman. “Deadlines are essential motivators, but safety must always trump schedule.”
At approximately 9:34 a.m. Mountain Time, during takeoff on the accident flight, the G-650 experienced a right wing stall, causing the airplane to roll to the right with the right wingtip contacting the runway. The airplane then departed the runway, impacting a concrete structure and an airport weather station, resulting in extensive structural damage and a post-crash fire. The two pilots and two flight engineers on board were fatally injured and the airplane was substantially damaged.
The NTSB made recommendations to the Flight Test Safety Committee and the Federal Aviation Administration to improve flight test operating policies and encourage manufacturers to follow best practices and to coordinate high-risk flight tests. And the Board recommended that Gulfstream Aerospace Corporation commission an independent safety audit to review the company’s progress in implementing a flight test safety management system and provide information about the lessons learned from its implementation to interested manufacturers, flight test safety groups and other appropriate parties.
“In all areas of aircraft manufacturing, and particularly in flight testing, where the risks are greater, leadership must require processes that are complete, clear and include well-defined criteria,” said Chairman Deborah A.P. Hersman. “This crash was as much an absence of leadership as it was of lift.”
A synopsis of the NTSB report, including the probable cause, findings, and a complete list of the safety recommendations, is available at http://go.usa.gov/YKYe. The full report will be available on the website in several weeks.
Cal Goat
Prestige Worldwide™
Yikes. I would have never thought that there was that kind of safety culture problem at prominent company in this day and age.
Boris Badenov
MAGA! F YOUR FEELINGS!
But they're IS-BAO certified! How could this POSSIBLY happen if you're IS-BAO certified?!??!
Well I mean with IS-BAO certification, it becomes clear that it was Rogue Pilots er "misinterpreting" the instructions they were given. I mean, the company was CERTIFIED! And COMPLIANT!
We occassionally have guys lift without a flight release. I swear to God you'd think they'd murdered someone's child. Meanwhile you've got dudes burning to death after a successful autorotation because the A-Star's fuel tank is basically a plastic can from a tractor. Are they hiring in New Zealand yet?
JustinS
Hopefully this was a real wake up call for Gulfstream to take a step back, and think about how they go about the flight testing program.
USMCmech
Did I miss the sarcasm tag or are you really that naive?
The larger and more prominent a company the more likely they have a safety culture problem. Take a look at BP's history of killing people in the petrochemical industry before the oil spill.
That said, flight testing a new airplane is a dangerous job no matter what anyone does.
Cal Goat
Prestige Worldwide™
I guess I'm naive.
MikeD
Administrator
Staff member
Which while true that it's a plastic can, an auto that's enough to puncture the fuel tank to allow a fire to start generally wouldn't be a non-injury one either, what with the vertical g-forces sustained (save for the anomaly accidents here and there with some crazy factor introduced). Then again, thats also one of the tradeoffs for weight savings when using a small helo like that for EMS, unfortunately.
