FPS is using both and will be for the foreseeable future. FPS is represented by the same union as dispatchers but no flow through. Moving from any IOC job to dispatch is all about staffing needs in each department which can slow movement down. At your age, I would go the regional route. Unless you really love scheduling, load planning or maintenance routing, a regional will likely get you in to dispatch faster. Most of our new hires are from the regionals.
As it stands now, the best you will ever do seniority wise is mid 300s which assumes the 200 above me all retire over the next 15 years. That likely wont happen so probably somewhere in the 400s is more realistic by the time you get to age 65. You need to be below 300 to get an international AM/PM line or any kind of decent coordinator line.
We have hired so many that it wont be easy for new hires going forward to have a very good qualify of life. You also need to look at the financial side. Top of salary is 11 years and 20 years with longevity pay. Every year you dont make it to dispatch reduces your chances of making it to top of scale before you are retired.
I have been here for 12 years now. I have another 30 years plus at least until retirement which is pretty typical for a lot of the 350 hired since Ive was hired here.
Timing is everything. I would make sure before switching jobs that you are comfortable with being on the bottom of the totem pole and first in line for furlough for most if not all your time in AA dispatch.
