New Aircraft Owner!
Cheechako
Lookee here! I bought me an airplane!
1967 Cessna 182L
cfa147faab12dec8a36c11c5c4ed8a03.heic
Congratulations!
Looks like you've got a stol kit on thed leading edge and is that the C-310 nose fork or just the angle makes the nose wheel look beefy?
Good eye! It’s got a Horton STOL kit (which rocks! I was holding altitude with full aileron authority at 40 mph indicated!)
7.0 on the 206 nose fork and 8.0’s on the mains.
Congrats! Nice looking plane. Be careful, the airplane bug only gets worse with time, next you'll be wanting sometimes juuuuust a little faster or with bigger tires, etc.
If you go with 8.50s on the mains DO NOT put one on the nose. You'll hate it.
As for paint, yes you're an AS pilot, but that 182 is an ALASKA PLANE, not some hangar queen. Display the wear and tear with pride!
You may want to put fueling steps on the struts and boot cowl. Sure makes fueling easier, especially when using your own gas cans.
I owned an L model for a couple years and sold it last year. Let me know if you have any questions about maintenance stuff! Great airplane!
PPonk is way way overrated. I may have had a couple lemons, but I would never put one of their engines on an airplane.
How/why?
I'm looking at a few 180's, 2 in California at the moment, one has a P-Ponk, the other 7 hours out of a major overhaul.
I don't need the power, but cruise/fuel burn/ economics per HP seem to tip in favor of the Pponk.
PS. A huge plug for PPonk gear. Seems like such a simple, cheap investment for stronger gear brackets.
PPS: It's a forgone conclusion I'll be buying one, but speaking of the 180/2/5 series, any guidance on throwing "in" long range tanks? Seems like it could be a great project for the next winter.
How/why?
PPonk O520 always had carb problems. They created their own carb jetting and just never got it right. PPonk overhauled IO550 had a case crack and a through bolt break. Honey bunches of nope.
You can't "throw" long range tanks into a short range wing. You need to replace or completely rebuild the wing.
Well, that idea has sailed. I have no justification to put 10 hours of gas in a plane.
Now that I think of it, just a bad idea all around.
It's got the Cessna heavy duty fork, which, I think, will accept up to an 8.00 (it's got a 7.00 now). Most likely at annual next spring I'll put 8.50s on the mains and move one of the current 8.00s to the nose gear... or should I keep the 7.00 up front?
Agreed! Maybe I'll have that done at annual also!
Re: pponk engine upgrade. Not on my radar. The current motor only has 300 hours, so maybe I'll revisit this in a few years...
Mine has long range tanks, but I doubt I'll be filling 'er up very often. Roger, re: winter care, should I keep the tanks full??
Over on backcountrypilot.org there is a lot of discussion about pponk jetting and various mods for the 18X family. Seems like the Dynon displays, Wing-X, and leading edge cuffs, and various tire/fork schemes get a lot of attention. It's definitely fun to read about the rebuilds some of the guys are doing. And on supercub.org there's a good thread about a rebuild done at Beegles.
Re: tanks full?
The lesson I learned down south, which applies up north as well:
I would leave the tanks full after each flight. Over a week's worth of heating/cooling relative to the temp I fill the tanks post flight, the fuel expanded and drained overboard. At least I know the vents weren't clogged...
I ended up staining the upper surface of the wing, since she was kept outside, until a sunshade came open.
I can't see any reason 100ll would do anything to a tank, after a month of sitting in a tank. Roger would know better.
