A website has been set up to help assist in registration for Network JC...If you have not yet registered, please use this website (network.jetcareers.com ) to do so. Once you register, you will be taken to a page that will list the hotel rate code needed to reserve your room(s).
It is your responsibility to reserve and pay for your room(s). Rooms must be reserved by August 24, 2004 and can be cancelled within 72 hours of arrival. As of right now, we have 30 rooms available, if needed, we can get more.
Please keep in mind when filling out the registration form that the first 5 lines are required.
However, If you get an error that says "email, pz_guest_name, b_last_name, phone, z_occupation: these fields must be filled in before you can successfully submit the form" -> it means you did not fill out the first 5 lines as required. I had some trouble with organizing the form, so the naming categories are a bit mixed up.
Also, for those of you bringing guests and/or spouses, I need their names in order to make sure they have a nametag waiting for them on the day of the event.
Thanks for your attention.
