seagull
Given that even I have been flying jets since before RVSM, yes, they all had said experience with certainty, and years of it.
Be careful on your wording, as it is extremely important... ALT 2 is "alternate law," which is the overall FBW regime that you're in. Direct law is another overall FBW regime with protections all gone.
Aileron control in ALT 2 is directly controlled by stick input, but it is not in "direct law." The difference, while subtle, is critical. She is twitchier in the roll, but it isn't awful... the 330 is very very stable with the phase length of control input to response almost twice as long as the 320. The 320 series has a much higher roll rate and is downright touchy in the roll in alternate and direct law (I've had the real thing in both laws in flight). One characteristic to note about the 330 in the roll is its behavior in heavy turbulence- it tends to wobble around up to about 7-10 degrees of bank.
I had flown the FAA A330 simulator in ALT 2 to 10 degrees past stall (not stall warning, but stall) AoA. I found it to be very easy to overcontrol with very low damping. This was a FL350 so low q factor. What altitude did you do this at?
Elaborate on how the pilot would perceive a difference between aileron control "directly controlled by stick input" (so not a rate control) and "direct law".
