Multi Comm Requirements
Pachong
Hey guys, hopefully this ones an easy one...
After checking the FARs, it's my understanding that if I have already completed the 300 nm cross-country flight in a single engine, that I do not have to complete this requirement in a multi-engine aircraft as well. Certain requirements specify "multi" while others do not. I don't have to do it right?
Sec. 61.129 Aeronautical experience
(b) For an airplane multiengine rating. Except as provided in paragraph (i) of this section, a person who applies for a commercial pilot certificate with an airplane category and multiengine class rating must log at least 250 hours of flight time as a pilot that consists of at least:
(1) 100 hours in powered aircraft, of which 50 hours must be in airplanes.
(2) 100 hours of pilot-in-command flight time, which includes at least—
(i) 50 hours in airplanes; and
(ii) 50 hours in cross-country flight of which at least 10 hours must be in airplanes.
(3) 20 hours of training on the areas of [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]operation[/FONT][/FONT][/COLOR][/COLOR] listed in §61.127(b)(2) of this part that includes at least—
(i) 10 hours of instrument training of which at least 5 hours must be in a multiengine airplane;
(ii) 10 hours of training in a multiengine airplane that has a retractable landing gear, flaps, and controllable pitch propellers, or is turbine-powered, or for an applicant seeking a multiengine seaplane rating, 10 hours of training in a multiengine seaplane that has flaps and a controllable pitch propeller;
(iii) One cross-country flight of at least 2 hours in a multiengine airplane in day VFR conditions, consisting of a total straight-line distance of more than 100 nautical miles from the original point of departure;
(iv) One cross-country flight of at least 2 hours in a multiengine airplane in night VFR conditions, consisting of a total straight-line distance of more than 100 nautical miles from the original point of departure; and
(v) 3 hours in a multiengine airplane in preparation for the practical test within the 60-day period preceding the date of the test.
(4) 10 hours of solo flight time in a multiengine airplane or 10 hours of flight time performing the duties of pilot in command in a multiengine airplane with an authorized instructor (either of which may be credited towards the flight time requirement in paragraph (b)(2) of this section), on the areas of operation listed in §61.127(b)(2) of this part that includes at least—
(i) One cross-country flight of not less than 300 nautical miles total distance with landings at a minimum of three points, one of which is a straight-line distance of at least 250 nautical miles from the original departure point.
(ii) 5 hours in night VFR conditions with 10 takeoffs and 10 landings (with each landing involving a flight with a traffic pattern) at an airport with an operating control tower.
Do you already have your CSEL? If so you are looking at the wrong section of part 61. You have no requirements for an add-on.
no it has to be in the multi, as well as the 10 take of and landings at night at a towered airport.
If you're doing Multi as your initial Commercial certificate, the aeronautical exprience requirements are the same as single-engne initial requirements only they have to be done in a multi-engine airplane. If you do it as an add-on, you've already fulfilled all the requirements except for some of the multi-engine-specific maneuvers on the checkride
