jeflies
Ok, I'll be the slow one today. .215(c) says "airspace as specified in paragraph (b)." Paragraph (b) says A, B, C, above 10,000 ft, and within 10nm of any airport listed in Appendix D, section 2.
How does that make it illegal to fly with the transponder turned off in class E?
99.13
(a) Aircraft transponder-on operation. Each person operating an aircraft into or out of the United States into, within, or across an ADIZ designated in subpart B of this part, if that aircraft is equipped with an operable radar beacon transponder, shall operate the transponder, including altitude encoding equipment if installed, and shall reply on the appropriate code or as assigned by ATC.
edit: after reading that pertains to ADIZ only. hmm
ah theres the right one. 91.215(c)
(c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an aircraft equipped with an operable ATC transponder maintained in accordance with Sec. 91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC.
