F9DXER
When an MEL is added the crew are required to abide by the restrictions of said MEL. Yet what if you know that the crew has no control over whether they can abide by said MEL, do you as the dispatcher add it or refuse to issue the release?
Yes that may seem a bit odd but let me explain.
In at least one Boeing type aircraft, the aircraft is designed to automatically determine whether to use VHF, SATCOM or HF for data transmissions. The software is programmed to look in that order as well. So if datalink is being used (which it always is), the crew has no idea which system is being used for data transmissions. Now an MEL is added that states HF datalink is deferred and unusable. Yet it is only on one HF unit, but there is no separate MEL number for HF1 or HF2, just for both. Thus both are considered not useable per the MEL.
Now here is the dilemma, the crew cannot control what the aircraft does, so would/could a violation occur?
Now you may ask why not just defer the faulty HF. Well, if I remember correctly, you cannot defer a working unit, since the HF works for voice communication. Correct me if I am wrong.
Any thoughts?
Any thoughts?
