nosehair
As I said, or thought I said, during the take-off or landing portion of the flight below the 100' and within the 1800 RVR.And when it's 100' and RVR 1800, you're going to do that how?
-mini
Specifically, I think we should track the runway during take-off to 35'. During this portion of the lift-off, the pilot can see any necessary drift correction and will be able to see if a turn to assigned heading would cause a safety issue.
And for the record, the strong 30 knot crosswinds that make this a problem don't exist with 100' ceilings and quarter mile vis. These conditions usually are a visual take-off to at least 4-500'. I'm talking about the strong x-winds for small aircraft where a 30 k wind is a half to third of the climb speed. The airplane will drift into an unsafe environment if you immediately go to heading on lift off.
This is not an issue for fast movers and climbers.
Plus, I'm not talking about the extended centerline area, just the over-the-run way portion.
