Cherokee_Cruiser
Bronteroc
What would cause this? The tail gear box just separates from the helicopter?appears to have come after the initial spin.
if the tail gearbox separated,
In the video it looks like the tail came off and the helicopter was already spinning out of control, before the main rotor struck the tail boom.
the pilot has to autorotate and get the engine shut off to avoid a spin or minimize any spin that has already occurred. And while doing that, keep the bird as level as possible with only controller turns and no gyrations….sometimes easier said than done.
That would already be a challenge because with the loss of the tail rotor and/or gearbox, there’d be a marked forward CG shift to overcome. If the helo isn’t kept somewhat level/upright in an autorotative descent, and especially with a helo equipped with a 2-blade semi-rigid rotor system, any max deflection of the rotor disc by the pilot with the cyclic stick, makes blade flex a high possibility along with the movement of the rotor system itself, resulting in a high probability of chopping the tailboom off the bird. At that point, the bird and anyone in it, is done, as the rest of the helicopter disintegrates on its way down to earth like a rock. At the end of the day, physics always wins.
I’m the dummy on helicopters, why can’t they be designed so even rapid full movement on the stick while climbing won’t hit the tail boom ? Isn’t it just a matter of placing the main rotor swash high enough?
What’s a controller turn?
If it loses the tail rotor (which it looks like they did here), won’t it immediately enter a spin? Which is what it looks like here. How do you prevent that in this case?
