Don't run a tank dry, run it till it has a gallon or two then switch to the other tank. There is absolutely no need to ever run a tank completely dry and you're just asking for trouble.
Why not?
Have you ever run a tank dry?
Why not?
Usually there is a bunch of crap at the bottom of the tank that could mess up your engine. Sand, silt and other undesirable stuff.
No, it's an unneeded risk. When would you ever cut your fuel reserves that close to need to run a tank dry, ever. Unless of course it's an emergency situation, well then everything goes out the window. In a fuel injected airplane you're susceptible to vapor lock and in a high performance airplane you're susceptible to abnormal temperatures.
TWA 800, is that you?![]()
Here's why I've done it in the past. Fuel was critical on this flight, and I wanted to make damn sure that I had used all the fuel in the tank before I switched. My fuel reserves only gave me about a 45 minute reserve, and the weather wasn't cooperating as forecast. Better to burn it dry than to eat up your reserve with left over fuel at the bottom of the tanks. I've done this in high performance fuel injected planes no problem. Plenty of old timers have even told me that this was standard practice "back in the day." I don't particularly see how this is "unnecessary risk," its fuel management. I don't particularly think that I'd be doing it in turbo'd birds for reasons of cooling, but that's a little different than the standard IO520 and IO540s that I'm used to. The IO520 doesn't relight as fast as IO540 in my experience, but click the boost pump on and all your worries of vaporlock go right away. If it were as dangerous or scary as some people make it out to be, there'd be airplanes vaporlocking and falling out of the sky daily as pilots forget to switch tanks in singles and burn one dry.
There has been quite a few NTSB reports because of people screwing up a tank switch after running it dry. It's great if you do it and you feel comfortable w/ it but it's not something I would ever give as advice, and I still believe it's an unnecessary risk. Just because it worked for you last time doesn't mean it will again this time. When the manufacture recommends against an action, it's usually good enough reason for me not to commit the act.
Certainly, people have frozen, or forgotten to switch back, or somehow bungled the restart problems. I also personally know someone who had one fail to relight on him. That said, it was an electric fuel pump failure to go along with it. Its useful under certain circumstances, including getting the maximum range out of your ship.
That said, I'd like to see where the manufacturer recommends against such an action. I've seen some manuals that say, "if it is desirable to run a tank dry in flight prior to switching tanks..."
I'd have to find it but it's in one of Lycoming's engine newsletter thingy.
Yes, but he's a CFI and presumably he's talking of dual instruction flights with primary to advanced students. Should that make a difference?
I once tagged along with a pilot in training for his commercial. We agreed I would do the W&B calcs. Otherwise, it was his flight on a short x/c out and back. At the destination I reminded the pilot we needed to refuel. He acknowledged then surprised me by taxiing back out for immediate takeoff. We returned to our original departure airport and I watched the lineman refuel to within ounces of useable fuel capacity. That pilot's CFI tried to give me the 3rd degree to which I responded, Your student was PIC.
What is going through the minds of students and how does the CFI affect that? The pilot in question, the son of a current 121 pilot, had no idea or concern for how close he came to becoing a statistic.
If you can track it down, I'd be interested in seeing it, I'm always willing and able to change my opinion on stuff like this.
http://www.lycoming.textron.com/support/tips-advice/key-reprints/pdfs/Key General.pdf
Page 18 I think, search for the word dry, it is in reference to fuel injected engines.
Since water and other contaminants collect on the bottom of the airplane fuel tank, it also makes good sense not to make a practice of running a fuel tank dry.
Although Supplemental Type Certificates (STC) now make the use of automotive fuel, which meets minimum specified standards,
legal for use in some aircraft, reciprocating engine manufacturers
and most major oil companies do not approve.
FAR 23.955(e) Multiple fuel tanks. For reciprocating engines that are supplied with fuel from more than one tank, if engine power loss becomes apparent due to fuel depletion from the tank selected, it must be possible after switching to any full tank, in level flight, to obtain 75 percent maximum continuous power on that engine in not more than -
(1) 10 seconds for naturally aspirated single engine airplanes; (2) 20 seconds for turbocharged single engine airplanes, provided that 75 percent maximum continuous naturally aspirated power is regained within 10 seconds; or
(3) 20 seconds for multiengine airplanes.
