Logging time in a Pilatus
the only possiblity is if you go fly with someone else who is a CFI or ATP rated in the aircraft, get a high altitude endorsment, then log it from that point as acting pic if and only if the PC12 doesent require a type rating.
Just to clarify this, an ATP w/ out a current CFI cannot just arbitrarily give flight instruction simply because they're rated in the aircraft. They must be instructing company pilots, in company aircraft, and be "in the business of air transportation (aka 121, or 135)."
I would be careful on logging this. Sure, legally, logging dual-given is OK with the endorsements. BUT in my opinion, it looks fishy to say you've been teaching someone to fly an aircraft that is VERY different than anything that you've flown before (I assume) unless you have experience in the aircraft, or have been thru a professional training school, etc. It's fast and heavy, it's got EFIS, and it's a turbine - I hear it's easy to fly, though.
If you DO choose to log dual-given, like others have said before, be prepared to answer some systems about the plane! Other than logging dual-given, maybe just ride along and just ask to fly the plane on some legs Will they let you?.
Upon further reflection on this matter, I see a couple scenarios where you can log this time as CFI. Say the owner needs a BFR. You can do that- you don't need to know anything about the airplane or its systems. You're just making sure he can fly the thing to fulfill the requirement of a BFR. CFIs do this all the time in airplanes they've never flown in.
Another situation- again with the owner or operator of the airplane. He wants to brush up on his instrument skills, do some commercial maneuvers (lazy 8s in a Pilatus? sweet!). You're merely instructing in flight maneuvers that you are well prepared and rated to instruct in. BUT, I wouldn't make a habit of logging dual given for hours and hours on end. It looks fishy!
[hijack]
Chris, just curious, why do have the free ipod site as your signature? What's up with that site? Did you get a free one?
[end hijack]
Now you could log PIC in the plane when you were the sole manipulator of the controls, since it is under 12,500. Has anyone mentioned this option?
[hijack]
[end hijack]
Haven't yet. Still need two more people to fulfill their trial offers. It's legit. I have a friend who has his in hand right now!
Technically legal? Yes. Now go explain that to an interviewer. Better yet, explain it to a lawyer and jury.
If you have to work this hard to be able to log something, it's probably not a good idea.
Thanks for all the advice. I think I will just ride along for fun and not worry about logging anything.
If you handle yourself like a pro, take an interest in the plane and the operation, impress the pilot and use your networking/schmoozing skills...good things will come your way.
Or at least that's what my fortune cookie said at lunch today.
I am in the exact same position with the same aircraft. The Captain is a CFI but his cert. has expired. He lets me fly all the empty legs, and has told me to log it as PIC time and has gone on to tell me to log the other time as SIC time. I have written the time as SIC in the log, but did not include in counting the hours. I realize I'm opening myself up for criticism, but any opinions or suggestions? I'm not a CFI and I'm only looking to log it as turbine experience not as dual given/recieved. Nothing I can do with whats already in the log?
It's a single pilot airplane, you can't log SIC in it, unless the regs you fly under require it AND you're qualified (ie, SIC check).
If you don't have the high alt endorsement, the PIC is going to look odd, even if it is legal. If you do have the endorsement, then have a ball on the empty legs.
I am pretty sure you do not need an SIC check to log SIC in a plane that does not require a type rating. Legaly I think you only need a commercial certificate and instrument rating in the proper category and class of aircraft and also meet all currency requirements.
Depends on how it's operated. If it's 135 charter stuff, odds are you'll need an SIC check. If it's 91 and single pilot, there is no SIC.
No offense, but I am pretty sure you couldn't be more wrong on this.
My understanding is in line with Kellwolf's: that to fly (and log) SIC on an aircraft certificated "single pilot" under a Part 135 certificate requires a statement in their ops spec calling for an SIC, plus an SIC check for the pilot concerned. Under Part 91 ops, I don't think there is such a provision at all. Under Pt 91, if the aircraft isn't certified as two-pilot, no one can log SIC time in it.
Then again, I might be full of •e.
Here at Purdue, junior year, students in the flight program get to fly about 15 hours in the right seat of a King Air 200. From what I hear they log it as SIC and do not have any kind of former SIC training. We do however have a semester long King Air ground school class which is required. Logging SIC in a plane only rated for one pilot is definitely not legal.
Is the 200 rated for two pilot op? If so, then you can log SIC time even if it's 91 since it requires two crewmembers. If not, that's logged time is questionable IMO.
From what I've heard, the King Air time is logged either as dual received and PIC or just dual received. Logging the time as PIC opens you up for interview questions and a lot of the people I've talked to feel it's smarter to just log the dual and not the PIC, although legally you could log it either way. SIC, however, isn't legal since the King Air is certificated for one pilot and Purdue operates them under Part 91, so there aren't any Ops Specs...Just my $.02
Dual recieved would make sense and be totally legal in that case. Actually, PIC might even fly (no pun intended) since you would be sole manipulator.
food for thought...
61.51(f) Logging second-in-command flight time. A person may log second-
in-command time only for that flight time during which that person:
(1) Is qualified in accordance with the second-in-command
requirements of Sec. 61.55 of this part, and occupies a crewmember
station in an aircraft that requires more than one pilot by the
aircraft's type certificate; or
(2) Holds the appropriate category, class, and instrument rating (if
an instrument rating is required for the flight) for the aircraft being
flown, and more than one pilot is required under the type certification
of the aircraft or the regulations under which the flight is being
conducted.
and then...
Sec. 61.55 Second-in-command qualifications.
(a) Except as provided in paragraph (d) of this section, no person
may serve as a second in command of an aircraft type certificated for
more than one required pilot flight crewmember or in operations
requiring a second in command unless that person holds:
d) This section does not apply to a person who is:
(1) Designated and qualified as a pilot in command under part 121,
125, or 135 of this chapter in that specific type of aircraft;
(2) Designated as the second in command under part 121, 125, or 135
of this chapter, in that specific type of aircraft;
(3) Designated as the second in command in that specific type of
aircraft for the purpose of receiving flight training required by this
section, and no passengers or cargo are carried on the aircraft; or
(4) Designated as a safety pilot for purposes required by
Sec. 91.109(b) of this chapter.
Yes, there is a way to log SIC in a single-engine aircraft under Part 91 regs.
Nice. Never thought about the "hood time" loophole since I normally think of the safety pilot as being acting PIC.
