Here... :banghead:
http://www.faa.gov/about/office_org...s/afs/afs800/afs810/part_61/media/pt61FAQ.doc
It's about 1/5 of the way down in the 61.51 section... I'll paste it here too... Don't say it doesn't apply... it does.
"QUESTION: I am sorry, but it is the age old Pilot-In-Command question again. As an examiner I am required to check the applicant's log book to determine that he meets the minimum aeronautical experience requirements for a certificate or rating.
Therefore, when an applicant is training for his instrument rating and commercial pilot certificate, an applicant has logged pilot-in-command while receiving dual instruction. In accordance with § 61.51(e)(1)(i), this is perfectly acceptable. Now when that same applicant is applying for his commercial pilot certificate which requires 100 hours of pilot-in-command flight time. If I use § 61.51 for guidance, then the PIC / dual flight time can be used to satisfy the 100 hours of pilot-in-command flight time requirement.
If I use § 1.1, then I must disallow the PIC / Dual flight time from the FAA Form 8710 application, which may disqualify the applicant.
I haven't had to deal with this on a practical test. But the question has arisen from an interpretation from a local flight school. Obviously the CFI's are eager to hear the REAL answer.
ANSWER: Ref. § 61.51(e)(1)(i); A rated pilot may log PIC flight time when that person “. . . is the sole manipulator of the controls of an aircraft for which the pilot is rated . . .” [See § 61.51(e)(1)(i)].
Do not confuse the PIC flight time logging requirements of § 61.51(e) with the legal definition of pilot in command in § 1.1. Look at it this way, the only time you need to be concerned with the legal definition of pilot in command in § 1.1 is when the FAA has you in court and our attorney is trying to prove in a court of law that you were the PIC. The legal definition of PIC in § 1.1 has nothing to do with the logging of PIC flight time in § 61.51(e).
As an FAA Aviation Safety Inspector (or you as a DPE), when I’m reviewing an applicant’s FAA Form 8710 1 application and logbook, the legal definition of PIC in § 1.1 has no relevance with my ascertaining whether the applicant has met the required PIC flight time to qualify for the certificate or rating. I leave the figuring out who was the legal PIC to the attorneys and judges.
So, in accordance with § 61.51(e)(1)(i), a rated pilot may log PIC flight time when that person “. . . is the sole manipulator of the controls of an aircraft for which the pilot is rated . . .” So whether the person’s flight instructor is on board or not, if that rated pilot “. . . is the sole manipulator of the controls of an aircraft for which the pilot is rated . . .” then that person may log PIC flight time.
In the case of the applicant for the Instrument – Airplane rating and the Commercial Pilot Certificate, you needn’t disallow the “logging” of PIC flight time because you’re trying to figure out whether the applicant was or was not the legal PIC. The “logging” of PIC flight time for a rated pilot is predicated only on the basis of § 61.51(e).
{Q&A-565}"
