msmspilot
IFR conditions are, by definition, any conditions that aren't VFR
Now, maybe you can tell me where you're still legally VFR when you're 100' or less above, below, or laterally from a cloud?
Might Class Bravo (provided you have 1 mile visibility, ring a bell?) That's an exception, btw
Wow. This is what I was trying to explain. Just because you're not VFR doesn't mean you're in flying solely by reference to instruments. You have to be flying solely by reference to instruments to log Instrument time. (61.51 (g)(1)) If you're less than VFR minimums from a cloud (100' outside Class B) but visibility is greater than 3sm, you're in VMC, but you're not VFR.
Yes, that means a dark night over water should count. You meet the requirements for VFR (you think, but have no way to verify), so you don't have to be instrument rated, but you're certainly flying by your instruments. So can you log PIC actual instrument without an instrument rating? Show me the reg that says you can't.
With that said, I probably wouldn't do it as it would look pretty questionable, and it certainly isn't the safest way to fly, but with the definitions that are in the regs, I can walk down that path.
