Turbine
What do you think about loading your flight plan into the GPS and saving it on the ground. Then after start loading it in and saving you some time.
This would all be done off the battery. Since you do not want to drain the battery you decide to pull a few breakers for the more consuming equipment, then reset them once you have finished.
Good practice or not?
