Chris_Ford
Kingairer said:Lights Camera Action sucks.
Finally. Where have you been!??!?!?!!
mtsu_av8er said:Not always!
I think you're missing mtsu's point. Even the airlines do not back up every flow with a check list, only the important ones. As an example the flow for an altitude change may be something like:Ralgha said:Alright, should always be backed up with a printed checklist. At airlines they are, and airlines seem to be what people are comparing this thing to.mtsu_av8er said:
SteveC said:I think you're missing mtsu's point. Even the airlines do not back up every flow with a check list, only the important ones. As an example the flow for an altitude change may be something like:
a) set altitude alerter,
b) select vertical speed mode,
c) set desired vertical rate,
d) adjust power as required,
e) monitor altitude,
f) monitor airspeed,
g) verify altitude capture,
h) adjust power as required.
I'm thinking that there is probably not a checklist for that, even at the airlines.
All right, to be technical (this is Technical Talk forum after allRalgha said:That's not a flow. There are a multitude of ways to change your altitude.
mtsu_av8er said:Airlines may be what everybodyis comparing this to. However, there's nothing saying that every flow even SHOULD be backed up with a checklist.
Raising the gear? Should that flow be backed up with a checklist?
Just curious. I'm not sure about airlines, because I've never flown for one. But, I still don't think that EVERY flow needs a checklist to back it up - if it did, then just use the checklist to begin with!
SteveC said:All right, to be technical (this is Technical Talk forum after all), what I spelled out is not a "flow", but a procedure. I suppose that the proper use of the term "flow" is a method of doing something (set-up or procedure) in a certain pattern, typically from one side of the panel to the other, or top to bottom, or from a certain sub-panel to another.
In my altitude-change example above I usually do parts of the procedure following a flow pattern. For example when I am the Pilot Flying I start at the top of the panel and hit VS mode on the A/P panel, move down to the power quadrant to adjust the power setting, and at the aft end of the pedestal I spin the wheel to dial in the vertical speed desired. Does that meet the definition of a "flow"? Or is there a definition that I'm missing?
The point that I was trying to work towards is that there are many "flow" patterns used in normal flying that do not have a checklist backup.
Like Ralgha said, it's not a flow, but yes, it should be backed up with a checklist and usually is in most airplanes. More important in some airplanes than others- as you could rip off the gear doors, or do damage to the hydraulic system if you simply flip the handle up and continue on your way without verifying that what was supposed to happen, did.mtsu_av8er said:Raising the gear? Should that flow be backed up with a checklist?
See, now that is a new definition to me (bold added for emphasis). Today is another good day - I learned something new.Ralgha said:...a flow is a specifically designed order of items done at a specific time that is standardized by the operator and used by all pilots in the same way at the same time.
No. Sometimes (rarely) is a "to-do" step by step list. Other times is a "did list" to recheck a flow. Still other times it's a briefing list - a chunk of information where you quickly review the upcoming procedure, like taking the runway, especially when you fly different airplanes.mtsu_av8er said:That actually IS our company flow.
Ahhh, the infamous "To-do" list.
MidlifeFlyer said:Not everyone is as perfect as those who eschew checklists, you know. Some of us actually manage to forget to turn on (or off) the boost pump or switch tanks in a Piper after flying a lot of Cessnas for a while.
Although you mention the gear as an example of something that does not need a checklist. Strange as it may seem, I've known of people who have forgotten to =raise= the gear in a retract (they fly fixed gear most of the time) and sat their wondering why the airplane was so slow that day. And most published checklists for retracts =do= have a "gear-- retract" item at least to tell you whether gear or flaps come up first (it does differ in different airplanes).mtsu_av8er said:Nobody is perfect, and nobody is eschewing checklists. Just pointing out that not every thing has, or should have, a checklist.
