tgrayson
It does so because more of the weight is in front of the C of G.
Er, that doesn't make sense. By definition, the weight ahead of the CG is the same as the weight behind the CG. That's why they call it a "Center" of Gravity.
I don't know why this would be associated with a stick pusher. Perhaps the stall characteristics are very poor when the directional stability is weak.
I have vague recollections of some talk about the airflow over the tail being partially blanked by the wings at high angles of attack and the elevator losing some effectiveness. Like jwp says maybe the fins help pitch the nose down during stall recovery.
I counted to a googleplex once
"...The delta shaped ventral strakes on the Avanti are most likely stall prevention devices, though they do provide some needed yaw stability. Such strakes were first used on the Lear Jet. At low angles of attack, the drooped strakes provide no lift; but at high angles of attack, they develop lift and raise the tail. The delta shape is key to this behavior...."
http://www.eng-tips.com/viewthread.cfm?qid=57055&page=12
"Here is the AIRCRAFT GENERAL DESCRIPTION from the Learjet 60 Pilot's Manual: ...Two inverted "V" ventral fins (delta fins) are fitted to the aft section of the tailcone to provide the aircraft with favorable stall recovery characteristics and additional lateral/directional stability."
http://www.anav8r.com/page01.htm
I'm not saying anything about the veracity of the above information. I'm just a Googler.
That's a bit vague. I can see that since the strakes have some orientation in the vertical direction, that once they assume an AOA with respect to the airflow, they would have a tendency to raise the tail or at least oppose the effort of the pilot to lower the tail. The way I would interpret this behavior is an effective increase in longitudinal static stability, which is measured by the effort it takes to move the aircraft from its trimmed AOA.
It's possible this effect could be large enough to prevent the max elevator deflection from producing a stall AOA, which is an effective reduction in elevator authority. But I suppose that the stick pusher has a similar effect.
Yep, after the 35 the newer Lears don't have pushers or "nudgers" -- just shakers. The delta fins fill that role.
The tail being partially blocked by the wings in t-tail airplanes is that "deep stall" we were discussing and supposedly the delta fins prevent the aircraft from entering that flight regime. I hope I never find out if they work.
