Just more circular thinking. The only thing that I see of note is the revision of the AIM. It sounds to me like they are differing to the AIM. They are placing all their eggs in the AIM.
But wouldn't that make the AIM a regulatory document instead of an INFORMATIONAL manual?
At least they decided to take a look at it. That is better than what they were doing.
:banghead:
It should. The FAA has been doing so for years.AIM might as well be treated as a regulatory document
...AIM might as well be treated as a regulatory document
"The AIM is not regulatory" is one of the great fallacies or half-truths about aviation law.But wouldn't that make the AIM a regulatory document instead of an INFORMATIONAL manual?
Yeah, I agree. Had an FAA Inspector on my CFI checkride tell me that you can do 360's on the end of the runway as long as the turns are in the proper direction. But you turn right instead of the left and they can bust you for not following proper FAR. Go figure. I am not saying that pilot's should not follow it but it seems that this is another way for the FAA to go around the NRPM process and edit the rules every few months instead of years. Something just doesn't seem to add up yet.
§ 91.126 Operating on or in the vicinity of an airport in Class G airspace.
(a) General. Unless otherwise authorized or required, each person operating an aircraft on or in the vicinity of an airport in a Class G airspace area must comply with the requirements of this section.
(b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace—
(1) Each pilot of an airplane must make all turns of that airplane to the left unless the airport displays approved light signals or visual markings indicating that turns should be made to the right, in which case the pilot must make all turns to the right;
Direction of turns in the pattern is in the regulations:
Maybe I didn't make that clear and I apologize. Yes the directions of turns in the pattern IS regulatory and the FAA can and will, if they so choose, do an enforcement action against you. I agree.
He was just commenting that, if it's left turns, make left 360's all day long in the pattern and not be in violation of the law.
Must be tired and not thinking clearly...sorry.
Well...since you asked for it:Correct me if I'm wrong...but I believe the only place you will see it written that you must get clearance to cross a hold short line is in the AIM as well.
This is the argument I use for anyone that uses the lame excuse that the AIM "technically" isn't regulatory Oh yeah? Where in the FARs does it say you must stop at a hold short line? :buck:
It is cathartically comfortable to discuss whether the AIM is / is not part of the FARs. . . what do you think about the interpretation regarding "known icing conditions"?
Translated to more human language the way I understand the interpretation is:
1. If there is known ice (e.g. pireps), then known icing conditions exist.
2. If visible moisture and below freezing temps exist, this is "known icing conditions", but you can still fly there without getting violated if you have an exit strategy (there are plenty of exit strategies, e.g. a sufficiently high ceiling to be able to descend below the ice, gaps between the clouds, etc.)
3. You can also fly into known icing conditions if your POH says the anti / de-icing systems can handle the ice.
I actually think the interpretation is reasonable. . . I'm a bit shocked at being able to agree with the FAA![]()
