My Flight Surgeon
Sr. Aviation Medical Examiner
This is one of a series of posts about medical issues potentially affecting a pilot’s ability to obtain a medical certificate. In this series, we will look at common problems seen by the AME, review the requirements the FAA has to consider allowing one to fly and discuss what you need to do to expedite consideration by the FAA to allow you to fly.
I would suggest that if you are unsure of how to answer these questions in Item 18, you discuss them with your AME before you complete the form. Some things may not be significant while others will require explanation.
Item 18y. Medical Disability Benefits
The applicant must report any disability benefits received, regardless of source or amount. If the applicant checks yes on this item, the FAA may verify with other Federal Agencies (ie. Social Security Administration, Veteran’s Affairs) whether the applicant is receiving a disability benefit that may present a conflict in issuing an FAA medical certificate.
*Italicized sections are excerpts from FAA documents.
