Item 18a - Frequent or severe headaches
My Flight Surgeon
Sr. Aviation Medical Examiner
Headaches
Headaches are common complaints from persons presenting to the physician’s office. The majority of these is simple tension headaches and requires only simple medication such as acetaminophen or ibuprofen. Even if they are longstanding the AME can issue a medical certificate without submitting a neurological evaluation to the FAA.
Item18a (Frequent or severe headaches) on the FAA Form 8500-8 (the one you fill out in the AME’s office) asks if there is a history of frequent or severe headaches. If so, the FAA states the applicant should report frequency, duration, characteristics, severity of symptoms, neurologic manifestations, and whether they have been incapacitating, treatment and side effects, if any.
The problem arises once a pilot is diagnosed with migraines, cluster headaches, chronic tension headaches or post-traumatic headaches. All of these conditions require a decision from the FAA regarding the issuance of a medical certificate. This is true for all classes of medical certificate. The problem with headaches is pain, in some conditions, may be acutely incapacitating. Chronic recurring headaches or pain syndromes often require medication for relief or prophylaxis, and, in most instances, the use of such medications are disqualifying because they may interfere with a pilot's alertness and functioning. The FAA wants to insure the condition is controlled and there are no medications that might disqualify a pilot from operating an aircraft.
If one has chronic tension headaches or cluster headaches, the FAA requires the airman to submit all pertinent medical records, a current neurologic report, to include characteristics, frequency, severity, associated with neurologic phenomena, the name and dosage of medication(s) and side effects. For post-traumatic headaches they require the pilot to submit all pertinent medical records, current neurologic report, name and dosage of medication(s) and side effects.
Migraine headaches are a bit different. The FAA wants to see an initial evaluation to include all pertinent medical records, current neurologic report, to include characteristics, frequency, severity, associated with neurologic phenomena, and name and dosage of medication(s) and side effects before they grant a Special Issuance medical certificate. The difference here is that once a Special Issuance is granted the AME can re-issue the medical certificate. The Special Issuance Authorization letter is accompanied by attachments that specify the information that treating physician(s) must provide for the re-issuance determination. For migraine headaches, AMEs may re-issue an airman medical certificate under the provisions of an Authorization, if the applicant provides the following:
  • An Authorization granted by the FAA;
  • A statement regarding the frequency of headaches and/or other associated symptoms since last follow-up report;
  • A statement regarding if the characteristics of the headaches changed; and
  • The name and dosage of medication(s) used for treatment and/or prevention with comment regarding side effects.
If these conditions are not met, the AME must defer the decision to the FAA.
The important take home points regarding headaches include: 1) if the headaches are severe and incapacitating one should not fly until they are evaluated and this may result in a Special Issuance of the medical certificate, 2) new onset severe headaches can be a serious problem such a brain tumor or hemorrhage into the head and need urgent evaluation, 3) If one has a headache, be certain the diagnosis is accurate and do not accept a diagnosis of migraine unless the headache meets the criteria, and 4) be cautious about medications prescribed for headaches by non-AMEs. They may write a prescription for one of the SSRI class of drugs (Prozac® or Zoloft®) which will result in disqualification from flight duties. If there are any questions about the medications prescribed, talk to your AME to coordinate appropriate management of the condition.
*Italicized sections are excerpts from FAA documents.
