CK
After reading through this section I was starting to get a little nervous. It seemed every thread I read about IR rides the person failed. I woke up at 5am on the 21st to meet the DE at an airport about 30 miles away by 8 am. After an hour drive to the airbase, an hour of doing the paper work so the airforce would let met leave I got off the ground by around 7:30.
The oral was pretty short and easy. What do these things on the enroute chart mean, how about this on on the approach plate, what do you need to be current, what does the plane need and he asked questions while we were in the air. We hopped in the plane and flew to the OM of the ILS into a nearby airport, he failed the left engine (I took it in the Seminole, I was already multi rated), but in the seminole that's not too big of a deal. About 30 seconds later tower asked us to break off the approach (they were using the runway opposite to us for take off). He told me to continue to fly on one engine and head towards the IAF of the GPS approach into the airport we started from. This is where the only mistake I made came from. I didn't put the gear up when we broke off the ILS! Before I noticed he said "The main thing you want to be thinking about on one engine is drag". I smiled and said "Damn" and put the gear up.
We went to the IAF for the GPS, did a teardrop entry and a hold then shot it and circled to land on the opposite runway. Luckily I ended it with a good note and made a good landing. While we were taxiing in he said something along the lines of I don't think you'll have any problem flying IFR. An half hour later I had my temp.
Now if only the T-storms will stop I'll get the chance to use it! I set my personal minimus to 2000' and 3 until I build up a little more experience. It'll certainly make life easy when I go in and out of the ADIZ.
Alex.
Alex.
