India Grounds All Airbus A320neos Over Concerns About Their American Engines
Springer
https://finance.yahoo.com/news/india-grounds-airbus-a320neos-over-164612622.html
India grounded all Airbus SE narrow-body planes powered by the latest Pratt & Whitney engines, taking unilateral action to remove the aircraft from the country’s skies after a series of in-flight incidents.
A320neos with even one Pratt engine featuring a seal found to cause vibrations are no longer allowed to fly, India’s DGCA said in a statement Monday. The action is at odds with the European Aviation Safety Agency, the primary regulator for Airbus planes, which repeated guidance that the jets are safe if they have a single affected turbine.
The Indian move immediately grounded eight aircraft at IndiGo, the nation’s largest carrier, and three at GoAirlines India Pvt. It comes after three in-service shutdowns of aircraft with one PW1100 engine featuring the seal, two of which occurred in the past week, according to the DGCA.
The glitch with the so called knife-edge compressor seal is the latest in a series of expensive problems for Pratt in its development of the geared turbofan engine model. The manufacturer, part of United Technologies Corp. had proposed a fix that would see at least one engine featuring an older seal reinstated on planes while it worked on a more permanent solution.
Nothing Concrete
Under the Pratt plan, all defective components would be replaced by early June, requiring some planes to fly with one affected engine for almost three more months. That’s not acceptable, according to the Indian regulator, which said the manufacturer had “no concrete proposal in place at this stage.”
Pratt & Whitney said in an emailed statement that it’s working closely with customers to minimize disruption and has already begun to deliver engines with the “upgraded configuration.” The U.S. company added that the “aircraft on ground situation” may take until the end of the second quarter to address. Of the 11 newly grounded Indian aircraft, as many as five may be able to recommence flying by swapping engines between affected planes.
EASA repeated a ruling that operations by aircraft with one defective engine should be permitted, provided such jets don’t undertake extended flights over water, where they’re more distant from diversionary airports in the event of an emergency.
The Indian decision was a “unilateral” one with which EASA wasn’t involved, the European agency said in an emailed statement, adding that a complete grounding “is not deemed necessary for the time being.”
Pratt replaced the original seal because it was degrading faster than expected, reducing the planned service interval. Indigo is both the largest current operator of the A320neo and the No. 1 customer. It and GoAir said they’d complied with the DGCA directive.
The most recent failure cause was the same as the other recent issues (knife edge seal). EASA, the FAA and DGCA have all been allowing aircraft to fly with one engine that has the defective seal, as long as the other engine doesn't (no ETOPS allowed). DGCA is now grounding all aircraft with even one effected engine. It will be interesting to see if the other alphabet agencies follow suite. The engines without the defective seal seem to be working just fine still.
Still. Not really an important detail in the story. Who cares where the engines are from? It’s not like they are grounded because of where they were built.
I think the article was trying to imply that somehow the Indian FAA was showing the Americans a thing or two about safety.
